ArcMap 10.6 - Is it possible to label features with domain descriptions instead of domain codes?
1502
05-14-2018 09:13 AM
BobBoutiette1
I have a zoning layer with a coded domain.  When labeling I would like the label to say Residential Single Family, which is the description instead of the code RSF.
Asrujit_SenGupta
Check this:Label Expression to Display Code from Coded Value Domain & How To: Display coded value domains and subtype codes instead of descriptions
They are actually the opposite of what you wanted, but may give you the idea...
BobBoutiette1
Thank you for your reply. Unfortunately I tried this and it did not make a change in the labeling just the table appearance. I want to use the domain description as the label
Bob Boutiette
GIS Analyst
IT Department
City of Murfreesboro, TN
Phone: (615) 893-6441 Ext. 1704
Email: [email protected]<mailto:[email protected]>
