ArcMap 10.5 - Report Poor Performance
1172
07-17-2018 01:38 PM
MichaelChretien
Hi, we're using ArcMap 10.5 to design some report for our client and facing really poor performance.
Environnement :
  • ArcGIS Desktop 10.5.1
  • ArcMap 10.5.1
  • Enterprise Geodatabase - Microsoft SQL Server 2016
We're trying to do a real simple report on 1 table.
  • The table contain informations about inspections (currently 206400 records and 25 fields)
  • The purpose of the report is to extract the number of inspections / per type / per inspectors
  • Runing the report in ArcMap takes around 8 mins.
Seing this i've runned a direct query on the database to obtain the same information and i did the same in excel via a database link.
  • Sql query takes less then 1 second
  • Excel pivot tables takes around 15 sec to refresh
The SQL query i used to get the informations :
select distinct(territoire), statutInspectionFinal, count(*)
from [xgi0100_geoinspection].[dbo].[XGI1105CE_INSPECTION_EVW]
group by territoire, statutInspectionFinal
order by territoire, statutInspectionFinal
I've read all documentations available and it seams there is no way to pass a real sql query to the report builder (U can only add expression to the select * query that is generated by the report builder)
Questions :
  • Is there a way to improve performance of the ArcMap report ?
  • What alternative is available for customers to generate report ?
Every Comments would be much appraciated.
Tks
Michael
AndresCastillo
regarding arcmap performance:
In the past, I Took some suggestions from the Github article to make ArcMap faster By Kevin Godsey
https://github.com/ncss-tech/geo-pit/wiki/How-to-Make-ESRI-Desktop-ArcMap-Faster
