Application Error in ArcGIS 10.3
1526
12-02-2023 01:13 AM
haripriyaN
while working in ArcGIS 10.3,ArcGIS desktop has encountered a serious application error and is unable to continue. kindly tell me how to solve this problem. I Couldn't  proceed further.
imanebenromdhane
I have no idea about the type of error, but based on my experience, you
should check the coordinate system or if you have performed multiple
operations in the same file, it might be overloaded. In that case, you may
need to open a new file or consider another solution, such as removing some
data after exporting them as a shapefile or in another forma.
haripriyaN
How to solve this problem which I attached in the image below?
imanebenromdhane
I'm sorry, but I couldn't find any image attached to your message. Could
you please provide more details or describe the problem you're facing? I'll
do my best to help you find a solution
imanebenromdhane
I also encountered challenges and faced obstacles that hindered my
progress. However, I came up with several solutions to overcome these
obstacles. The key is to experiment with different approaches and not
get discouraged. I am confident that your determination will lead to
success and enable you to complete your work. Good luck!
[image: Community Verified icon]
