25 feet polygon layer shows in ArcMap but not in ArcCatalog
1179
05-05-2022 10:58 AM
Labels (3)
JoseSanchez
Good afternoon,
I created a 25 feet polygon buffer around a point layer, and when I open the buffer layer in ArcCatalog I do not see any feature, also when I open the same layer in ArcMap, features are not visible, I do have to zoon in a lot to see anything.
Is that normal?
wayfaringrob
Honored Contributor
If you have to zoom, it sounds likely you've got a scale range set. See anything on the general tab of the layer's properties? Select "Show layer at all scales" to clear those settings.
RhettZufelt
MVP Notable Contributor
If not zoom scale related, sometimes corrupt features will cause that as well.
Can try the Repair Geometry tool on the buffer feature class to see if that resolves it.
R_
RobertBorchert
Honored Contributor
Well 25 feet is a VERY small buffer.  I would expect you would need to be zoomed in to less than 1:500 to even see the features.
