Workflow Manager AOI in WGS84 and Editable Layers in NAD83 State Plane
907
03-06-2025 01:06 PM
AndreLoerch
Using the modern Workflow Manager with Pro 3.3. Our editable layers use NAD83 and a state plane projection. Defining an AOI seems to create the AOI exclusively in WGS84. When viewing the AOI overlaid on the map, we can see an offset of 1-3 meters between the defined area and editable layer features (polygons). Because we have set the AOI rule for 'outside', and because there is an apparent offset caused by the transformations between WGS84 and NAD83, the features we want selected are not.
Is there a workaround for this?
Is it expected that editable layers need to use WGS84 in order to work with Workflow Manager, and if so, is that stated anywhere in the documentation? I've been unable to find this stated anywhere.
Gfreitag
I would also like to know the answer for this. We are running into the same issue.
