Work Flow Manager Base Map
2225
06-17-2013 08:04 AM
MikeJohnson2
Greetings,
Where can I find documention on creating a map to use as the Work Flow manager basemap?
I created a custom basemap from the Arcgis server (REST services) and would like to remove the dependency of the ArcGIS server    for a client side DLL.
Mike
by Anonymous User
Not applicable
Hi Mike,
If you go into the help file and go to Configuring Workflow Manager ->Maps it will explain how to add the maps you create into your Workflow repository.
Cheers,
Michael
