Time Gated Steps ?
1407
09-07-2023 10:24 AM
DEWright_CA
When setting up a workflow that has a "Approval" question, how/can we put a time-gate on it. I am looking for if a Deny hasn't happened in 5 days that it auto-approves and the workflow continues.
Tags (1)
SamWest1
Hello! It sounds like Step scheduling should help out with your use case. You can set a step to wait a period of time, and then have it automatically release the hold and run the step. For the manual approval case, the hold will need to be released as part of that approval process, as it also blocks the running of the step until that scheduled time.
Hope this helps you out, and be sure to let us know if you have any further questions
DEWright_CA
No quite, we need to be able to have a If/Else scenario. So if we hit the time-gate; then auto-approve.
