JTC file
2378
03-07-2013 11:17 AM
MikeJohnson2
Greetings,
Is a new JTC file required to switch between WFM database connections?
For example:
A test database and production database using Oracle 11g.
The differences between the test and production databases are server names, port numbers, database name and user id and password for the connection properties.
Michael
AlisonGaiser
Michael,
You are correct, you will require two unique .jtc connections.
We have this situation in our environment (for select users). The QA environment is the default for those users in the development group, but you can quickly switch to the Production environment if required.
Each connection is named differently and contains connection information to different servers, databases, and logins.
Alison
