How do I add Remote SDE Instance to ArcGIS Workflow Manger Instance Post Installation
2742
11-06-2013 12:45 AM
VivekGaikwad1
Hi All,
I have SDE database running on a different server, I have installed ArcGIS Workflow Manager on a different system, Now I am trying to run ArcGIS Workflow Manager post installation, were I am not able to understand how Do I specify my Instance.
Example:ArcSDE 9.3 Oracle 11g Database Name : ABCD123 Instance : 1234_abc System Name : ABCD123
ArcGIS Workflow Manger : 10.2, System Name : XYZ54321
Kind Regards
Vivek
by Anonymous User
Not applicable
Hi Vivek,
You can use this article as a guide for inputting the Oracle connection instance information into the Workflow Manager Post Install dialogue.
http://resources.arcgis.com/en/help/main/10.2/index.html#//00290000003q000000
Cheers,
Michael
VivekGaikwad1
Hi Vivek,
Cheers,
Michael
Hi Michael,
Thanksa lot for your reply and sharing the document. I am able to make a direct SDE database connection. The acutal issue was with Oracle Client application (Oracle Instance Client 32 bit), I installed this applictaion then I later I was able to make a dirct connection.
Once again, Thanks  a lot for your reply.
Kind Regards
Vivek
