Can not access to WMrest
2858
07-09-2012 11:08 PM
EduardoGonzalez
I´ve installed WMX Server, I can publish WMX objects, but I can not access to http://[myserver]/wmrest/services/
I have this error:
{"error":{"code":400,"message":"Invalid URL. Parsing error; missing \u0027WMServer\u0027 in URL.","details":[]}}
Some help please?
Thank you
KevinBedel
Hi Eduardo,
With Workflow Manager Server on ArcGIS Server .Net, it is not supported to browse the services in the way you are attempting. Instead, you must connect directly to the service. For example, at http://[myserver]/wmrest/services/[myservice]/WMServer
If you are wanting to view what services are published, you can use ArcGIS Server Manager, or the Workflow Manager Servers node in ArcCatalog.
EduardoGonzalez
Ok! Thank you very much!
