PostgreSQL client files are installed with ArcGIS Pro and ArcGIS Server;
you do not need to install a PostgreSQL client or set environment variables to access the client.
ArcGIS Documentation:
Connect to PostgreSQL from ArcGIS Server on Windows
Connect to PostgreSQL from ArcGIS Pro
ArcGIS Requirements for PostgreSQL
What PostgreSQL database versions are supported by ArcGIS Enterprise and ArcGIS Pro?
Connect to PostgreSQL from ArcGIS Server on Linux
Microsoft ODBC Driver for SQL Server on Windows - ODBC Driver for SQL Server | Microsoft Learn
Note: ArcMap 10.8.2 does not work with ODBC 18 and for those machines must install only the ODBC 17
Read my white paper - How to Install the SQL Server Client for ArcGIS?
Connect to Microsoft SQL Server from ArcGIS Server on Windows
Connect to Microsoft SQL Server from ArcGIS Pro
ArcGIS Requirements for Microsoft SQL Server
What SQL Server database versions are supported by ArcGIS Enterprise and ArcGIS Pro?
Microsoft ODBC 18 - "must follow the steps in the document below"
Install the Microsoft ODBC driver for SQL Server (Linux)
Connect to Microsoft SQL Server from ArcGIS Server on Linux
Notes:
Instant Client for Microsoft Windows (32-bit) - ArcGIS Desktop ( ArcMap & ArcCatalog )
Instant Client for Microsoft Windows (x64) - ArcGIS Pro & ArcGIS Server
expand the "Installation Instructions" for more information
Connect to Oracle from ArcGIS Server on Windows
Connect to Oracle from ArcGIS Pro
ArcGIS Requirements for Oracle
What Oracle database versions are supported by ArcGIS Enterprise and ArcGIS Pro?
Instant Client for Oracle Linux
Instant Client for Linux x86-64 (64-bit) (oracle.com)
expand the "Installation Instructions" for more information.
Connect to Oracle from ArcGIS Server on Linux - Important !!! Read this documentation !!!
A few more important remarks.
*OCI – Oracle Call Interface API
“basic” – all files required to run OCI, OCCI, and JDBC-OCI applications
“sqlplus” – SQL Plus command line tool for SQL and PL/SQL queries
“tools” – Data Pump, SQL Loader, Workload Replay tools
“jdbc” – additional support for internationalization under JDBC
“odbc” – additional libraries for enabling ODBC applications
“devel” – additional header files and example makefile for developing Oracle applications with Instant Client
# su – root
# yum install oracle-instantclient-basic-21.11.0.0.0-1.el8.x86_64.rpm
# yum install oracle-instantclient-sqlplus-21.11.0.0.0-1.el8.x86_64.rpm
Connect to Oracle from ArcGIS—ArcGIS Server | Documentation for ArcGIS Enterprise
In the link above please read: Connect from ArcGIS Server | Set the LD_LIBRARY_PATH environment variable
$ su – arcgis <== Linux User running the ArcGIS Server Service
$ vi .bash_profile
export PATH=/usr/lib/oracle/21/client64/bin:$PATH
export LD_LIBRARY_PATH=/usr/lib/oracle/21/client64:$LD_LIBRARY_PATH
:wq!
Note: PATH variable needs to include “/bin” in the directory path to be able to call “sqlplus”
If you are using the Oracle database Instant client libraries, you only need to uncomment and set the $LD_LIBRARY_PATH, for example:
# For connection with Oracle Instant Client
Save and close the script.
To do this, run the stopserver.sh script, then run the startserver.sh script on each machine in the ArcGIS Server site.
./stopserver.sh
./startserver.sh
$ sqlplus /nolog
connect sde/<password>@mcsdboralnx7:1577/topo1.esri.com
show user_name
show con_name
exit
Now users can use
or
https://docs.oracle.com/en/database/oracle/oracle-database/26/lacli/supported-ubuntu-distributions-f...
https://docs.oracle.com/en/database/oracle/oracle-database/21/lacli/supported-ubuntu-distributions-f...
https://docs.oracle.com/en/database/oracle/oracle-database/19/lacli/instant-client-install-linux.htm...
https://docs.oracle.com/en/database/oracle/oracle-database/19/lacli/install-instant-client-using-zip...
https://docs.oracle.com/en/database/oracle/oracle-database/19/lacli/install-instant-client-using-rpm...
To install Oracle Instant Client on Ubuntu 24.04 (Noble Numbat), follow these steps.
This process focuses on the ZIP file method, which is the most reliable way to avoid RPM compatibility issues.
1. Install System Dependencies
Ubuntu 24.04 replaced the old libaio1 package with libaio1t64.
Since the Oracle client specifically looks for libaio.so.1,
you must install the new package and create a symbolic link.
Update and install required tools:
sudo apt update
sudo apt install -y libaio1t64 unzip
Create the necessary symbolic link:
sudo ln -s /usr/lib/x86_64-linux-gnu/libaio.so.1t64 /usr/lib/x86_64-linux-gnu/libaio.so.1
2. Download the Instant Client
Go to the Oracle Instant Client Downloads for Linux page.
Required: Download the Basic Package (ZIP) (e.g., instantclient-basic-linux.x64-23.x.x.zip).
Optional: Download the SQL*Plus Package (ZIP) if you want a command-line interface to the database.
3. Extract the Files
It is standard practice to install Oracle software in /opt/oracle.
Create the directory:
sudo mkdir -p /opt/oracle
Unzip the basic package (replace the filename with your downloaded version):
sudo unzip ~/Downloads/instantclient-basic-linux.x64-23.7.0.25.01.zip -d /opt/oracle
/* Oracle Instant Client 19.30
unzip -q /tmp/instantclient-basic-linux.x64-19.30.0.0.0dbru.zip -d /opt/oracle
unzip -q /tmp/instantclient-sqlplus-linux.x64-19.30.0.0.0dbru.zip -d /opt/oracle
This creates a folder like /opt/oracle/instantclient_23_7.
4. Configure Environment Variables
You must tell Ubuntu where to find the Oracle libraries and binaries.
Add the library path to the system configuration:
sudo sh -c "echo /opt/oracle/instantclient_23_7 > /etc/ld.so.conf.d/oracle-instantclient.conf"
sudo ldconfig
sudo sh -c "echo /opt/oracle/instantclient_19_30 > /etc/ld.so.conf.d/oracle-instantclient.conf"
sudo ldconfig
Update your user profile to include the binaries in your PATH. Open your .bashrc file:
bash
nano ~/.bashrc
Append these lines to the end of the file (adjust the version number to match your folder):
export LD_LIBRARY_PATH=/opt/oracle/instantclient_23_7:$LD_LIBRARY_PATH
export PATH=/opt/oracle/instantclient_23_7:$PATH
export LD_LIBRARY_PATH=/opt/oracle/instantclient_19_30:$LD_LIBRARY_PATH
export PATH=/opt/oracle/instantclient_19_30:$PATH
Reload the profile:
source ~/.bashrc
5. Verify the Installation
If you installed the SQL*Plus package, you can verify everything is working by typing:
sqlplus -v
You should see the version information without any "shared library not found" errors.
marc7777@ubuntu2404ora:~$ sqlplus /nolog
SQL*Plus: Release 19.0.0.0.0 - Production on Fri Mar 13 21:50:22 2026
Version 19.30.0.0.0
Copyright (c) 1982, 2025, Oracle. All rights reserved.
SQL> connect gis/****@mcsdboralnx.esri.com:1577/topo1.esri.com
Connected.
SQL> show con_name
CON_NAME
TOPO1
SQL> show user
USER is "GIS"
SQL> disconnect
SQL> exit
