ArcSDE User-Schema Geodatabases in Oracle are deprecated.
MarceloMarques_1-1720461608715.png________________________________________________________________________________________________
What are the deprecation plans for ArcGIS products?
MarceloMarques_2-1720458030864.png________________________________________________________________________________________________
IMPORTANT: If you are using ArcGIS Pro 3.x and trying to edit data and use geodatabase features like Traditional Versioning and or Branch Versioning with an ArcSDE User-Schema Geodatabase in Oracle, then this is not a recommended nor a supported workflow with ArcGIS Pro.
You can learn how to setup the new Oracle CDB in the database guide books for ArcGIS Pro in my community.esri.com page.
Read the ArcGIS Pro “Production Mapping” database guidebook for Oracle and the database connection best practices.
I discuss a lot of best practices in the database guidebook, and I explain in detail how to setup advanced Oracle features like Oracle Encryption (TDE) and Oracle Compression.
The guidebook is just a start point that the Oracle Database Administrator & Geodatabase Administrator need to read.
Then after that is highly recommended to download the database template scripts for Oracle also available in my community.esri.com page.
The database template scripts have a lot more best practices and recommendations on how to setup, manage, and maintain the Oracle Geodatabase.
