URL Parameters in ArcGIS Web Editor
1071
08-23-2024 10:43 AM
HaleyBrueckman1
I am testing out having a web map in Experience Builder where you can select a feature, and in the pop up there is a link to an editor. When you select that link it will take you to another editor app and it already has the feature that was previously selected in the experience builder app selected in the editor. One option is to create an editor in Experience Builder and use a URL parameter in the popup, which will direct to that ExB app. I was curious if I could do the same with thing with the ArcGIS Web Editor? Can I set up a URL parameter that will use the object id of the selected features and open the ArcGIS Web Editor with this feature already selected and ready to edit?
CraigGillgrass
@HaleyBrueckman1 not at this time but it is something we're working on for the 11.3 release (which will be available as a separate setup in September) and the Fall release of Online.
In addition to the web map, the Web Editor will support url parameters for extent, find or locate a feature and version (for versioned services).
TrafficOpsGIS
Appreciate the info. Looking forward to the updates.
