Editing tools are inactive
3715
12
09-24-2024 01:10 AM
JohnGoat
Editing tools are inactive, how can i edit operation?
JohnGoat
Hi @lzorloni
I did what you said but it didn't work, or maybe I didn't quite understand what you meant.
Can you please show me with a screenshot?
CraigGillgrass
@JohnGoat the workaround that @lzorloni used is to change to another version and then change back to sde.Default..  In your screenshot, select the "B.test_y" version, you should see the Create Feature tool enable.  Then, open the Versioning dialog and change back to sde.Default, you should see the Create Feature tool enable.
If this doesn't address your issue, feel free to contact me at [email protected] so I can help.
Craig
JohnGoat
ok i am andurstand @CraigGillgrass but it didn't work for me, the create feature menu is still inactive.  I sent you an email
thanks
