Why do labels disappear when the Smart Editor Widget is activated?
1836
06-19-2017 12:57 PM
ChristopherSchreiber
Hello,
I am using the Smart Editor Widget in a v2.1 WAB DE application. I noticed that when I start the Smart Editor widget, any labels that are created for a layer disappear for that layer. Once I turn off the Smart Editor widget, the labels re-appear. Has anyone come across this, and if so, is this a bug, or is it supposed to behave this way?
Before SE widget is turned on:
While SE widget is active:
After SE widget is closed:
Thank you!
Chris
RobertScheitlin__GISP
Chris,
   The most likely case is that label editing is not supported and thus disabling the labels is the best way to not have the user think that they can edit those.
Chris,
