Where to change App ID for import into WAB dev environment
2107
07-21-2016 01:25 PM
DavidColey
MVP Frequent Contributor
Hi - so I've had to switch computers and put up another WAB dev environment.  Unfortunately, I created an app where the node server gave it an ID of 2, e.g.
.../webappbuilder/?id=2
the same ID as an app I am trying to import from my other WAB dev environment.   Does anyone know where I can change the ID of the downloaded app so I can perform an import?
Thanks-
David
RobertScheitlin__GISP
David,
I would not think that that would be a problem as the WAB Dev Tingo database on the machine is what assigns the app id based on the position the app is add to in the database.
DavidColey
Thanks Robert, I would agree.  However, once I brought over a couple other deployments with different IDs, and then went back and ran the import again.  Successfull.  At my first attempt, I had just the one new app with an ID of 2, same as the app I was trying to import and recieved a duplicate ID error in the command window.  It's like the Tingo was stuck on an index?
