Weird behavior from dijit/form/combobox with LaunchPad theme
2307
03-19-2017 11:23 AM
Alexwang
Hello, I have a dijit/form/ComboBox in my LaunchPad theme app. The combobox works, but the weird thing was that the control still got focused even when I moved cursor below the box - please see below. When I click it, the drop down list opens. When I change theme from LaunchPad to a Tab, I didn't notice any weird behavior. I assume the LaunchPad theme adds some styles to the dijit controls, is there a way to remove or overwrite these styles? Thanks for your help.
LaunchPad theme:
Tab theme:
RobertScheitlin__GISP
Alex,
   I am not seeing this behavior on my end. In you image do you notice that your mouse cursor is a pointer still? When you mouse cursor is a pointer over a combobox the combobox is in hover over mode and thus still get the focus rect around it.
Alexwang
Thanks Robert. When i didn't apply a custom height to the combobox, everything worked. But after i gave it a height (in my case, 35px) less than the default height, the weird behavior appears.
Alex,
   Are you adding the height in the combobox style property or as a css rule?
Alexwang
Thanks Robert.
I programatically set it like
configComboBox.set('style', {width:'200px', height: '45px'});
Alex,
   Even when I do that in the lauchpad theme for a combobox when I click off the CB the focus rect is removed...?
