WebApp Builder / Flex Viewer - Problem with Postal Code / ZIP Codes
7584
11
05-12-2015 06:44 AM
ThomasSteudel1
Hello Community,
since the beginning of my work with Flex as well as with the new WebAppBuilder i have a problem with the representation of postal codes / ZIP code within the PopUp.
My shapefile was created within ArcGIS. I had points and joined some information to them. The information from an external table also included Postal Codes. After the table join everything looks fine in ArcGIS.
An Example: Postal Code as shown and stored within my shp-file: 91126
Now my problem:
Within Flex Viewer as well as within the WAB my postal code is reformated:
Within Flex the example Postal Code changes to: 91.126  (the option to use 1000-seperator within the pop up configurator is off)
Within WAB the example Postal Code changes to: 91.126,00
Where can i define the representation of fields including a number? I do not want to change the field in a string field.
Does anyone have any experience and maybe a solution to the shown problem?
Best regards and thank you in advice,
Thomas
RobertScheitlin__GISP
Thomas,
   You have to open the actual thread you will not see the correct answer link in your inbox view or custom stream view.
ThomasSteudel1
Hi Robert,
thank you for this tipp and thank you again for your help and correct answers.
