WebApp Builder 2.3 - Add Data Widget Error
2527
03-28-2017 11:12 AM
OverlaysS
When the Add Data Widget is restricted to only permit layers from AGOL, the page scroll buttons jump to the top of the widget and page numbers disappear. But if the the URL or File option is enabled, the page scroll buttons accurately appear at the bottom of the widget.
(See images attached)
Please how can this be rectified?
Offie
DerekLaw
Esri Esteemed Contributor
Hi Overlays,
I just tested your workflow with Web AppBuilder for ArcGIS Developer Edition v2.4 and was unable to reproduce your issue. Suggest you upgrade to the 2.4 release.
Hope this helps,
OverlaysS
Hi Derek,
Thank you for the suggestion, the issue has been resolved in version 2.4.
