Web AppBuilder "Attribute links" prefacing link with portal URL
1543
06-17-2021 07:05 AM
by Anonymous User
Not applicable
I've added a link to a web app and the link is being prefixed with the portal URL.
This isn't the behaviour I remember...
Tags (1)
jcarlson
It does this sometimes if your URL isn't formatted just so. It's not WAB doing it, but rather the web map itself. Without the "https://" or "http://" in front of the URL, it will assume the link is a relative URL to something else in your portal / org.
Here are two links. Note the address preview at the bottom of the browser.
Does this address your issue, or is it something else?
- Josh Carlson
Kendall County GIS
John_Spence
Can you provide an example/screen shot of what you are looking at?  Is your link being generated by Arcade code?  If yes, can you provide that as well?
jcarlson
- Josh Carlson
Kendall County GIS
by Anonymous User
Not applicable
Ah, that simple. It's been a long day...
