Web AppBuilder attributes
4093
04-15-2016 11:21 AM
JoseSanchez
Hello everyone,
This question is about how to add logic in ArcGIS Online to fields that are populated by application, not by data entry.
I was able to create in ArcGIS Online a Web Mapping Application that has only one layer. The layer is a feature service pointing to SDE in a versioned environment.  The layer is a polygon.
The ArcGIS Online web mapping application works fine. It  allows to digitize a new feature polygon and populate its attributes.
My question is about how pre-populate some  attributes with default values such as:
  • Date Created, Date when record was created
  • CreatedBy, Editors User ID
  • DateModified, Date when record was modified for the last time
  • ModifiedBy, Editors User ID
  • PrimaryKeyID, populated with a sequential number, obtained from a sequencer in Oracle
  • Other fields  like municipality or commission district that are populated with the value of the Municipality or Commission district where this polygon intersects
For desktop applications I solved this issue creating an ArcMap Add-In.
In the old Web ADF I solved this issue using the event:
  • Protected Sub EditorTask1_PostToolExecute(ByVal sender As Object, ByVal editorToolEventArgs As EditorToolEventArgs)  Handles EditorTask1.PostToolExecute
I would like to know how to do that with Web AppBuilder
RobertScheitlin__GISP
Jose,
  See this thread for the answer:
https://community.esri.com/thread/170004#comment-576213
JoseSanchez
I took a look to this link.
I do not see any event that will trigger when the editor creates or modifies a new feature.
This is what I would like to implement that works already in an Add-In:
'Invoked when a feature is created or modified
    Private Sub Events_OnCreateFeature(ByVal obj As ESRI.ArcGIS.Geodatabase.IObject)
        Dim inFeature As IFeature = CType(obj, IFeature)
        Dim featureClass As IFeatureClass
        Dim intNextMyEditableLayerId As Integer
        featureClass = CType(obj.Class, IFeatureClass)
        DisplayFieldNamesAndAliasNames(featureClass)
        '     MsgBox(featureClass.AliasName)
        If featureClass.AliasName <> "MyEditableLayer" And featureClass.AliasName <> "APP.MyEditableLayer" Then
            Exit Sub
        End If
        '  GetConnectionStrings()
        intNextMyEditableLayerId = NextMyEditableLayerNumber()
        ' Populate the next MyEditableLayerID available
        Dim fieldIndex As Integer = featureClass.FindField("MyEditableLayerID")
        If fieldIndex = -1 Then
            Exit Sub
        End If
        inFeature.Value(fieldIndex) = intNextMyEditableLayerId
Jose,
  Your add-in code has little bearing in WAB. The thread I pointed you to allows for autopopulating a field with data before the feature is created on the server. The event that is used is the features before-apply-edits
AndresCastillo
I know this post has been here a while, but I am going to try the smart editor widget.
