Web App Directions Widget Requires Sign-in ?
4761
5
02-27-2016 06:37 AM
FatmaŞenol
I'm working on creating an interactive web map application for our campus.
Please note that all web maps used in application are hosted on our ArcGIS
organizational account The application seems to be working except for  the `Directions` widget.
When I try to use it, sign-in page for  our organizational account is opened in browser.
I tested it in different browsers but the result is the same.  Can you suggest a solution for
this issue ?
Regards,
RobertScheitlin__GISP
Omur,
   Routing requires the use of credits, thus the need for the login dialog.
Omur,
FatmaŞenol
Robert,
Thank you for the information. Apparently, I missed this point. So, every end user should be a member of organizational account to use directions widget. If this is the case, using limited credits for every routing request might not be the best solution.  Would it be possible to use google maps for routing in a web application ?  If so, how ? I hope I'm not asking for too much.
Omur,
   You can setup your app using the esri proxy with rate limiting that could be configured to to the login/authentication automatically and you can set the rate usage.
GitHub - Esri/resource-proxy: Proxy files for DotNet, Java and PHP.
If that does not suit your needs then you can develop a custom widget that uses Google routing as long as you comply with Google Terms of Use and you are a developer. This thread on Stack Exchange may help if you want to go that direction:
How to create routing application with ArcGIS Server? - Geographic Information Systems Stack Exchang...
RobertLackage
I see using AGOL there is a 'subscriber content access' for saving credentials so that the public may use the Directions widget. How would this be accomplished using the developer appbuilder?
Install the esri resource proxy and save your credentials in the proxy.config. Follow the directions I posted in my reply to Omur.
