Web App Builder Attribute Table
1770
11-10-2021 02:25 PM
by Anonymous User
Not applicable
Hello - in my web map, I have used the configure attributes to configure my pop ups.  But when I apply the attribute widget to my dashboard, and export the data to excel the fields are not organized the way they were in the pop up.  Essentially it seems I have to configure the attribute widget as well.
I would like to know if this is correct - that the attribute widget does not use the configuration from the pop up and I have to reconfigure the data using the configure layer fields.
Thank you,
Annette
tigerwoulds
Yes - you are exactly right. Popups and attribute tables are two different things, so they have to be configured separately.
tigerwoulds
