Web App Builder 2.12 Map Services wont load
3592
6
05-10-2019 01:57 PM
GeorgeKatsambas
My WAB version 2.12 will not see my published map services when accessing through the web application developer edition 2.12, however, the web apps on our arcGIS Server do show the map services. If I use a previous version of WAB, 2.11 then I do not get the error map services not found. I deleted my signin.json, re added my appid etc still did not help. Before I remove wab 2.12 is there an easy fix to this as i do not want to re-import all my apps and re-customize them.
Tags (1)
RobertScheitlin__GISP
Correct it would affect all versions... Strange. When you open the signin.json is it listing the portal url as http or https protocol?
George,
  Did 2.12 every work on your machine? If not then there is no big loss deleting 2.12 and and re-upgrading from your previous version.
GeorgeKatsambas
It did work, now for some reason its directing me to https:\\, I guess deleting and re importing apps is ok, just dont feel like doing all my customizations and css rules again
Did you make any changes to your organization's security setting or any thing?
GeorgeKatsambas
Thats what I need to look into now, if our IT department pushed out something, would that not affect though V2.10 or 2.11?
GeorgeKatsambas
Thanks Robert, the signin was using https, no idea how it changed, ( i must have done something) but switching to http seems to fix it for now.
