Way to round value in popup?
798
10-30-2025 07:44 AM
GeorgeJonesRIGOV
toaSqft_Text.pngsquareFeetRound.png Hi all, looking to round the square feet value to nearest hundredth. Is there a way to do this programmatically inside of ArcPro?
thanks GJ
CodyPatterson
MVP Regular Contributor
Hey @GeorgeJonesRIGOV
You will need to use the "Edit Map" functionality to transfer onto the Web app:
Once inside, you can go to the layer, then to configure popups:
Then to Configure Attributes:
Finally selecting the attribute would let you change the format:
I find it kind of strange that it's changing the text field to numeric, so you may need to use Attribute expressions below the "Configure Attributes" button as well, but let me know if needed!
Cody
CodyPatterson
Cody
