WAB: How to get popup info from feature layer via js function?
2335
03-09-2020 10:06 AM
MarkJones7
Good Afternoon,
I was just wondering if it is possible via JS to get a layers popup information? I was hoping to just grab the info and send it to another widget.
Any help is greatly appreciated.
Mark
WilliamCraft
I don't believe this is possible when working from within the WAB framework of Portal.  You would likely need to use the developer edition of WAB if you're not using it already.
MarkJones7
I am using the Developer version of WAB.
RobertScheitlin__GISP
Mark,
   In JS the way you get the current popup info is:
var atts = this.map.infoWindow.getSelectedFeature().attributes;
MarkJones7
Thanks Rob.
I gather I will need some type of handler to listen to the map for when a feature is selected? Using on click doesn't seem right since it would fire where ever the user clicks on the map. =]
MarkJones7
figured it out. =]
evtHandler = this.map.infoWindow.on('set-features', function(){
        console.log(atts);
thanks again.
