WAB Edit Widget - Trace Features
2486
02-27-2021 06:24 AM
DavidPike
MVP Notable Contributor
WAB Standalone Enterprise Portal10.6.1
Oracle SDE-served Feature Service
We have an editable polygon feature service, and snapping is possible by holding Ctrl on vertex creation.
Is tracing at all possible? - both to itself and other separate feature services such as land parcels etc.?
If not, do you have any suggestions/workarounds?
Cheers.
LongDinh
Hi David Pike,
I imagine it would be possible by creating a new widget or extending the Edit/Draw Widgets in JavaScript 3.x/4.x or TypeScript. I am not aware of any open source solutions.
Thinking conceptually, I would start with creating a new WAB Widget with a similar workflow to ArcMap/Pro's trace functionality. The widget should:
  1. Select a layer/s to be used to trace.
    1. Add the layer's geometry to a feature set containing Points, Lines, Polylines,
  2. Create a feature/graphic.
    1. Uses the ESRI Draw tools JS library
    2. Add some event handlers to draw tools
Steps 2 will have most of the challenges, specifically the event handlers. Some event handlers to replicate the Trace create feature tool in JS may be:
  1. On 1st map click: begin draw. If within snapping tolerance of trace feature set geometry and snap to feature and geometry, else, draw by map click
  2. On next map click: check snapping tolerance to trace feature set geometry and snap to feature and geometry, or release trace.
  3. If snapped to feature set, read the next/previous feature segment of the geometry. paths
  4. On double click: release and finish feature. (close out polygon if incomplete)
  5. and more.
DavidPike
Thanks very much for the ideas.
