WAB Developer 2.1 Widget Issue
2719
07-20-2016 12:55 PM
ShawnBowers
I've noticed this issue with both the Layer list and the new Select widgets where they work as expected locally, but when I download and deploy there are issues.  Once deployed both widgets lose the three dots where you pull up the additional context menu.  I've tried with different themes with the same results.  Can anyone else replicate this issue?  Below, the first two examples are in WAB and when I "launch" from WAB.  The second two are after I download and deploy to our web server.
RobertScheitlin__GISP
Shawn,
  You need to add the .svg mime type to your web server.
W3C SVG Server Settings
Lemao Wu​ this probably needs to be added to the documentation.
Shawn,
ShawnBowers
Worked perfect, thanks Robert!
