WAB Dev 2.6: AddData Widget
3697
11
02-02-2018 06:12 AM
JamesCrandall
Am I correct in understanding that the AddData Widget that is included with WAB Developer v2.6 does NOT allow for kml/kmz files?  I don't see that option in my installation.
It is available option on the hosted WAB Developer, but I want to make sure that what I see in my WABDev2.6 install.
MichaelAugust
Did you figure out a workaround for KML for the error you mention above? We're still getting the "Unable to load" error on local KML files we try to upload while building the app in WAB dev edition...thanks!
MichaelLinden
Yes, I've gotten mine to work. Did you start building your app in 2.6? That was the problem with mine. I needed to upgrade the actual application not just the SDK.
