WAB 2.1 Print widget - disable copyright text
3626
8
08-22-2016 10:29 AM
DavidColey
MVP Frequent Contributor
Hi -  I know this info has been posted up before but I just can't find it.  Does anyone recall where to disable copyright text?  Would it be here in the Print.js:
var hasCopyrightText = lang.getObject(
 'layoutOptions.hasCopyrightText', false, templateInfo);
 if (!hasCopyrightText) {
 html.setStyle(this.copyrightTr, 'display', 'none');
 } else {
 html.setStyle(this.copyrightTr, 'display', '');
Thanks-
David
Tags (1)
RobertScheitlin__GISP
David,
  In the Print.js change the print function as indicated below (add line 24):
print: function() {
      if (this.printSettingsFormDijit.isValid()) {
        var form = this.printSettingsFormDijit.get('value');
        lang.mixin(form, this.layoutMetadataDijit.get('value'));
        this.preserve = this.preserveFormDijit.get('value');
        lang.mixin(form, this.preserve);
        this.layoutForm = this.layoutFormDijit.get('value');
        var mapQualityForm = this.mapQualityFormDijit.get('value');
        var mapOnlyForm = this.mapOnlyFormDijit.get('value');
        lang.mixin(mapOnlyForm, mapQualityForm);
        var elementsObj = this.customTextElementsDijit.get('value');
        var cteArray = [];
        for (var p in elementsObj) {
          var cte = {};
          cte[p] = elementsObj[p];
          cteArray.push(cte);
        var templateInfo = this._currentTemplateInfo;
        var hasAuthorText = lang.getObject('layoutOptions.hasAuthorText', false, templateInfo);
        var hasCopyrightText = lang.getObject('layoutOptions.hasCopyrightText',
        hasCopyrightText = false;
David,
print: function() {
        var cteArray = [];
          var cte = {};
          cteArray.push(cte);
DavidColey
Ah yes, that's it thanks.
DavidColey
I also unfortunately misspelled 'copyright' in the post title. . . geez
RebeccaStrauch__GISP
you should be able to edit/update your title.  Probably worth fixing.
DavidColey
I tried but I can't get at the text
ha...someone was able to fix it.
David when you go to edit a post it does not look like you can click in the title and change it but you can (FYI as I have done it already).
DavidColey
Ha! Good one, thanks Robert-
