WAB 1.2 Edit Widget
5901
10
10-09-2015 07:56 AM
JoshEllis
I am unable to edit features using the WAB 1.2. The services are able to be edited on the webamp in AGO. I have the edit capability turned on and the widget configured for those layers. Any ideas>
RickeyFight
Josh,
Do you get any errors in your console log?
JoshEllis
Not sure where the console log is located, but it appears like it is going to work except when you click to add a point or select it just does nothing.
Josh
RickeyFight
Josh,
Can you post your app so we can look at it?
To access your console log, right click and select inspect element (works in chrome and Firefox)
We are looking for errors in red
JoshEllis
Does this help at all? When I click the widget and then try to add a point this happens in the console.
RickeyFight
Josh,
What layer are you trying to edit?
JoshEllis
RickeyFight
Josh,
Maybe try to create a new app.
I got the layer to work here:
ArcGIS Web Application
I created two points with TEST in the notes
JoshEllis
I am trying your app and it will not work for me. I tried it with chrome and firefox,  can not drop a point.
RickeyFight
I see what you are seeing now.
I am getting this error
I am not sure what it means
