WAB 1.2 developer edition Launchpad Theme doesn't clear widget results
6614
15
08-25-2015 12:52 PM
MariaNieves
I am having issues with the Launchpad Theme on WAB dev edition 1.2. Widget results do not clear after closing widget. Anyone having same issue?
MariaNieves
I have a few widgets so some of them go on a different panel. I just tested and the widget works as expected if the Google Street View Widget is on the main controller. It doesn't when it is part of the other panels. google_street_view_pegman2.png
RobertScheitlin__GISP
Maria,
   Oh, now I see the issue. I will work on a fix for this.
As far as the LaunchPad theme here is a workaround that can be applied to each widget that has some dependence on the onClose event. I will be adding this workaround to each of my widgets in their next releases.
I add the dojo/aspect require and then in the postCreate function I add the code below.
        /*Workaround for the LanunchPad theme not firing onClose and onOpen for the widget*/
        if(this.appConfig.theme.name === "LaunchpadTheme"){
          var tPanel = this.getPanel();
          if(tPanel){
            aspect.after(tPanel, "onClose", lang.hitch(this, this.onClose));
            aspect.after(tPanel, "onOpen", lang.hitch(this, this.onOpen));
        /*end work around for LaunchPad*/
I have tested this using my eSearch, Identify, StreetView and they all work well with this workaround using the LaunchPad theme.
MariaNieves
Thanks Robert!
JunshanLiu
DanielSieger
I have found that this behavior only occurs when the widget is added to the Anchor Bar Controller. Adding a widget to the number widgets section does not have this behavior.
This only happens in the ArcGIS Web AppBuilder 1.2 Developer Edition. It does not happen in ArcGIS Online's built-in Web AppBuilder.
