Using SOAP with default proxy
7145
12
02-21-2018 01:34 PM
FrancisGagne1
I'm trying to POST a SOAP request on a service not under my control.
Since it's cross domain, I need to use a proxy.
I am only using Postman for now.
When I call the service directly, the response is good. But when I add https://myserver:3344/proxy.js? before my service url in postman. The service return me "Server was unable to process request. ---> Root element is missing." meaning that my xml I sent is not good anymore.
Can I have some help with SOAP request using the default proxy coming with WebApp Builder?
Is it supported?
Thanks.
CCWeedcontrol
Robert i have some questions if you don't mind.
What data are you retrieving from the CAMA system, what are you doing with it?
How exactly are you doing it?
RobertScheitlin__GISP
What data: All required parcel and improvement info for the selected parcel
What I do with it: Generate JS/HTML custom reports
How Exactly: Using esriRequest to my custom .Net web service that returns the CAMA data based a parcel number query.
FrancisGagne1
Instead of using the proxy in WAB to handle the cross domain problem, I passed in a service that handle CORS and all is fine now: https://cors-anywhere.herokuapp.com/
I'll setup a cors-anywhere on my client's server but at least I know that works with this one.
