Using Custom Widgets in AGOL and Portal
9737
21
04-11-2016 05:42 PM
RandallClark2
So i know, or i think, that this has been asked many time before but i am still unclear as to if it is possible or not , especially since the release of 10.3 and now 10.4 but is there a way to use custom widgets that i make using WAB Dev or that others have made.
Really for the time i am interested in widget made by others.
Anyone care to enlighten me?
KathleenWallis
Randall - Please go through the pdf found at the link below.
Robert Scheitlin has developed many custom widgets. Read the tapasdas pdf at the link above in Rebecca's message. So the answer is yes. If you
download the WAB developer's addition you can then incorporate custom widgets. It is all in the pdf.
Katy
DerekLaw
Esri Esteemed Contributor
FYI, with the release of ArcGIS Enterprise 10.5.1, Web AppBuilder embedded in Portal for ArcGIS now supports custom widgets. Please see this blog,
Web AppBuilder for ArcGIS now supports Custom Widgets in ArcGIS Enterprise 10.5.1 | ArcGIS Blog
Hope this helps,
