Using an Array in the for loop of an Arcade Expression
3078
06-18-2020 06:15 PM
DonSjoboen
Hello Xander Bakker
I'm trying (unsuccessfully) to use an Array in my for loop to return the unique route (along with other columns) that is in a related customer table.  See example below...
The top table is my customers table (i.e. related table), and the bottom table is my point feature class.  The related fields are "CO_ID = CONNECTION_OBJECT".
Below is my Arcade expression...
var tbl = FeatureSetByPortalItem(Portal('https://organization.com/'), 'ItemID', 1);
Console(Count(tbl));
var id = $feature["CO_ID"];
Console(id);
var sql = "CONNECTION_OBJECT = '" + id + "'";
Console(sql);
var customers = Filter(tbl, sql);
var myArray = customers;
var cnt = Count(customers);
Console(cnt);
var result = "";
if (cnt > 0) {
for (var k in myArray) {
/* var ROUTE = myArray[0];
console(ROUTE);
result += TextFormatting.NewLine + "Routes: " + ROUTE +
*/ result += TextFormatting.NewLine + k;
} else {
result = "No customer data"
Console(result);
return result;
What happens is that I get the right ID and count of related records, but I keep getting the last record (in my customers table) repeating 4 times, with the same route "R003N".  What I am trying to get is something that looks like this for the popup...
Address: 123 Main St
Customer: John Doe
Business Partner Number: 111111111
Contract Account: 222222222
Routes:
F0001 / [CommSup] / M
FC01 / [CommSup] / F
GL01 / [CommSup] / M
R003 / [CommSup] / M
Thanks in advance for your help!  Let me know if you have any questions or need further clarification.
Don
XanderBakker
Esri Esteemed Contributor
HiDon Sjoboen ,
Quick question; is the field CONNECTION_OBJECT numeric or string? If it is numeric you should omit the quotes around the ID when you construct the SQL.
DonSjoboen
Hello Xander Bakker,
The field [CONNECTION_OBJECT] is an integer.
XanderBakker
Hi Don Sjoboen ,
Did you try changing the "sql" like this?
Console(id);
var sql = "CONNECTION_OBJECT = " + id;
Console(sql);
Console(cnt);
var result = "";
if (cnt > 0) {
    console(ROUTE);
    result += TextFormatting.NewLine + "Routes: " + ROUTE +*/
} else {
Console(result);
return result;
