Using 24 hour time in Smart Editor widget
1159
01-14-2019 01:26 PM
Clint_Glover
I am currently using the Smart Editor widget inside of Web AppBuilder Developer Edition (version 2.10) and I have a date field that needs to use 24 hour time (HH:mm:ss).  I have set that field in the Portal web map to use 24 hour time, but it seems that the Smart Editor widget is either ignoring or overriding it.  The Smart Editor widget appears to only want to use h:mm:ss am/pm time format no matter what the date/time format is set to in the Portal map.  I'm not sure if this is intentional behavior by the Smart Editor widget, but whether it is or is not, does anyone know of a solution to fix my issue?  For reference, I am using ArcGIS Enterprise (10.5.1).
