URL query popup in WABde 2.0 - EMPTY - Bug?
7040
16
04-08-2016 03:51 PM
MichaelRobb
Honored Contributor
When using URL Query...
web map opens... zooms to queried feature.. popup occurs... but is Empty.  Of course if one clicks again on the line, the popup populates...
Can anyone confirm this?
Is there a known fix?
MichaelRobb
Honored Contributor
Have you tried this in AGOL?
by Anonymous User
Not applicable
I have not tried in AGOL yet.
MichaelRobb
Honored Contributor
If the problem follows, then Id look at data next...
If it works in AGOL but still doesnt in-house, Id look at the 2.2 WABde upgrade or verify that indeed the web app contains the Javascript to handle the popup query.
by Anonymous User
Not applicable
It does not work in house or on ArcGIS online. Here is what I get:
MichaelRobb
Honored Contributor
oh my... wouldn't that be a kicker if the 2.2 release is broken again. 2.1 works. Ill test both 2.1 and 2.2 and post results.
MichaelRobb
Honored Contributor
yep, this appears to be an issue again with 2.2.  This function works with WABde 2.1.
MichaelRobb
Honored Contributor
Looks like this Broken again in WABde version 2.2.
