Unable to View Attachments in Web Application
726
06-03-2022 12:23 PM
KariWilliams1
Hi all,
I'm in the middle of building a web application with two layers that have photos under Attachments in the attribute table and it shows up as a link on the web application, but in Map Viewer/Map Viewer Classic, I have it set up so that it automatically displays the photos in the popup. I'd like to have this option in the Web Application, but I'm not seeing a solution yet. I've seen this post, but the toolbox keeps failing in ArcMap Pro, and I'd have to run a task scheduler and use ArcMap Pro, I'd rather not do that if I don't have to.
Has anyone run into this issue before and did you find a solution?
Thank you all.
NoahWasserman
Have you found a solution? It seems like it's not possible to have both 1) Attached photos appearing in popup, and 2) configure popups in New Map Viewer.  Which is another insane incompatibility that ESRI should have fixed before they launched New Map Viewer.  Right now it seems like most (all?) Instant Apps require Map Viewer Classic to honor the popup configuration, but Map View Classic won't show attached photos, it only shows them as links.
