unable to retrieve an App ID
3737
6
02-27-2016 02:08 PM
FatmaŞenol
I'm trying to setup Web AppBuilder for ArcGIS  (Developer Edition). I need to provide
the App ID and followed the steps explained in
Get started—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
Unfortunately, I got error message saying:
Unable to load
http://iyte.maps.argis.com/sharing/rest/content/users/IYTE-ARCHITECTURE/addItem status: 0
Could you please kindly let me know the reason of this message ? Thank you in advance.
RobertScheitlin__GISP
Omur,
   What type of account do you have and what is your permission level for that account?
FatmaŞenol
Robert,
Thank you for your reply. We have ArcGIS Online Organizational Account as a part of academic site license. My permission level is administrator. Thank you.
Omur,
    I have not run into that error before. Are you able to add a new webmap or other item without error? Have you tried multiple times to add a new application item and get the same error each time?
FatmaŞenol
Robert,
Yes, I am able to add a new item such as a webmap without any problem. As for the second part of your question, I haven't tried multiple times to add a new application item  So, I have to try to add new application items to see if I keep getting the same error. I will try and let you know the result as soon as possible. Thank you.
RebeccaStrauch__GISP
Two different looks at getting the appid setup
Tips and Observations for getting Web AppBuilder - Developer Edition Installed
http://www.tapasdas.com/WABv2.pdf
Sometimes there is just an issue on how you set up the app in AGOL, and it is better to start that process over.
AravindatStoryMaps
Hey Omur,
Can you also choose the option "Application" instead of "web mapping". This will not show the URL parameter. But let's see if this lets you create an application or not. Will throw some light into what kind of application causes this error.
