The Smart Editor widget displays the template search bar twice.
1470
06-22-2017 01:21 PM
ChristopherSchreiber
Hello all,
I have noticed that the Smart Editor Widget in WAB DE 2.1 loads the search template bar twice when a layer is chosen,  a feature is added, and then the Smart Editor Widget is closed and reopened.
Example:
  • Open the widget and select a layer to edit:
    • The layer selected is "Polygon"
  • Add a feature
    • Select "Save"
  • Smart Editor template search behaves normal
  • Close the Smart Editor Widget and then reopen it.
    • Result:
If anyone has come across this before, please let me know!
NOTE: To fix the error, the WAB app must be refreshed.
Thanks!
Chris
Hello all,
I fixed the issue, but I'm sure that it is not the best way to do it. Here is what I came up with. Please let me know if there is a better way to go about this! Thank you!
     postCreate: function () {
          //################# My Edits###############//
          var r = /\d+/g;
          var id = this.id;
          var matchValue = id.match(r);
          console.log(matchValue);
          if (matchValue[0] != 0) {
              domConstruct.destroy("jimu_dijit_SEFilterEditor_" + --matchValue)
          //################ End Edits ##############//
        this._createFilterTool();
This is located in the postCreate function in the "SEFilterEditor" js file.
Thanks!
Chris
Hello all,
          var r = /\d+/g;
          var id = this.id;
Thanks!
Chris
