SSL in Web App Builder
11972
20
02-09-2016 07:42 AM
Syvertson
Hello.
I have just created an application with web app builder (This is using portal, not AGOL, and using the "Create Application using Web App Builder" in the portal)  Immediately we had errors saying that access was forbidden.  After a day or so, I realized that the problem is that the app builder creates a URL that is not SSL, and I have my web server set to only accept SSL.  The temp solution is to just add the "https://" to the URL in the address bar after it gives one that won't work.
How do I get the app builder to give me a good address using https from the start.  I know it must be able to be changed in the settings somewhere, but where???
Thanks.
Matt Syvertson
RickGeittmann
One thing we ran across on the local install of Portal is the inability to run in mixed mode - as in we bring in the HTTP REST end point from NOAA for the stream gages and things do not work correctly.
