Simple elevation profile widget
1836
01-16-2023 10:32 AM
JenniferGrove
Hello, Community,
Is there a simple elevation profile widget available in the Enterprise portal?  I would like to use it in a web map.  However, I do not see one in the ArcGIS Web AppBuilder.  Is there a reason?
When I try to create web app using configurable apps, I do see that under explore/summarize data, there is an elevation profile.  However, I am unable to get it to work.
Thanks for any help in advance!
--Jennifer
AlixVezina
@JenniferGrove  That is correct, the widget is only available at Enterprise 11.0 or in ArcGIS Online. A workaround could be to set up the Experience Builder developer edition and register an application to your Portal.
JayantaPoddar
Maybe you could work with Experience Builder.
Elevation Profile widget - Experience Builder
Think Location
JenniferGrove
Thank you for the suggestion.  I appreciate it.  I'm not sure the widget is in experience builder.  We're using Enterprise 10.9 and I don't see the widget in there.
AlixVezina
