Renaming Enhanced Search Widget
4342
15
01-25-2017 11:24 AM
WilliamMiller4
I renamed Robert's Enhanced Search Widget after making some changes. I am able to go through the setup in web appbuilder, but when I click OK to complete the widget's configuration, I get the error below and no option to save the changes. The widget is copied to the app, but no config file is saved. I've removed my code and just changed the widget name in all the files (attached), and I've tried restarting WAB multiple times, but the problem persists. Any help is greatly appreciated.
Thank you.
William
TypeError: Cannot read property 'en-us' of undefined  init.js:113
  at Object.<anonymous> (FeatureActionManager.js?wab_dv=2.2:174)
  at Object.forEach (init.js:70)
  at Object.registerWidgetFeatureActions (FeatureActionManager.js?wab_dv=2.2:162)
  at Object.<anonymous> (FeatureActionManager.js?wab_dv=2.2:207)
  at init.js:63
  at visitBigSection (utils.js?wab_dv=2.2:120)
  at Object.visitElement (utils.js?wab_dv=2.2:85)
  at Object.c.visitElement (ConfigManager.js?wab_dv=2.2:177)
  at Object._reRegisterWidgetActions (FeatureActionManager.js?wab_dv=2.2:204)
  at Object._onAppConfigChanged (FeatureActionManager.js?wab_dv=2.2:252) "TypeError: Cannot read property 'en-us' of undefined
  at Object.<anonymous> (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/FeatureActionManager.js?wab_dv=2.2:174:82)
  at Object.forEach (http://js.arcgis.com/3.18/init.js:70:348)
  at Object.registerWidgetFeatureActions (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/FeatureActionManager.js?wab_dv=2.2:162:15)
  at Object.<anonymous> (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/FeatureActionManager.js?wab_dv=2.2:207:28)
  at http://js.arcgis.com/3.18/init.js:63:209
  at visitBigSection (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/shared/utils.js?wab_dv=2.2:120:13)
  at Object.visitElement (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/shared/utils.js?wab_dv=2.2:85:5)
  at Object.c.visitElement (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/ConfigManager.js?wab_dv=2.2:177:19)
  at Object._reRegisterWidgetActions (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/FeatureActionManager.js?wab_dv=2.2:204:19)
  at Object._onAppConfigChanged (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/FeatureActionManager.js?wab_dv=2.2:252:14)
  rejected at a (http://js.arcgis.com/3.18/init.js:108:174)
  at h (http://js.arcgis.com/3.18/init.js:107:438)
  at g.then.c.then (http://js.arcgis.com/3.18/init.js:110:152)
  at Object._onWidgetPoolChanged (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/ConfigManager.js?wab_dv=2.2:285:72)
  at f.<anonymous> (http://js.arcgis.com/3.18/init.js:63:209)
  at f.c [as onbuilder/widgetPoolChanged] (http://js.arcgis.com/3.18/init.js:119:79)
  at Function.h.emit (http://js.arcgis.com/3.18/init.js:124:331)
  at Function.h.emit (http://js.arcgis.com/3.18/init.js:125:443)
  at f.emit (http://js.arcgis.com/3.18/init.js:117:218)
  at Object.publish (http://js.arcgis.com/3.18/init.js:169:289)
Error
  at g.then.c.then (http://js.arcgis.com/3.18/init.js:110:97)
  at Object.<anonymous> (http://pcName.domainName:port/webappbuilder/builder/main.js?wab_dv=2.2:2111:232)
  at f.<anonymous> (http://js.arcgis.com/3.18/init.js:63:209)"
WilliamMiller4
Robert,
I do see an eLabels widget in the add widget dialog when I create a new app, but when I click OK, I get the error above.
William
RobertScheitlin__GISP
William,
   Did you make all your changes in the client/stemapp/widgets folder or server/apps/[app#]/widgets folder?
WilliamMiller4
Hi Robert,
Initially, I was just modifying your widget in an app. When I realized I needed a separate widget, I transferred to working in the stemapp.
William
WilliamMiller4
The widget attached to this thread is from the stemapp folder.
William,
  Do you still have an unaltered eSearch in the stemapp folder?
WilliamMiller4
Yes.
