Remove / delete custom images is not an option in Web Appbuilder?
5079
9
09-08-2020 07:45 AM
PRuss
I have added about a dozen custom images in Web Appbuilder and when trying to modify or delete them there doesn't not appear to be a way to do this...
What am I missing?
Tags (1)
RobertScheitlin__GISP
What exactly do you mean by
PRuss
using imgur urls with the '+'  button
e.g. https://i.imgur.com/lD0pD4V.png
But where in WAB are you talking about. In a widget or the app framework...?
PRuss
app framework i believe... please see the attached screenshot in my op.
OK. That is why this question did not make sense. That screenshot is from AGOL Map Viewer, when you are editing the web map in WAB. It actually has nothing to do with WAB. I will put a mention of ArcGIS Online space where someone can probably answer this question.
ArcGIS Online
PRuss
i posted it in the AGOL forum and got no replies: https://community.esri.com/message/952517-remove-delete-custom-images-is-not-an-option
can you please eil5 how this is not a WAB issue?
Because when you click the button to edit the webmap you are now using the AGOL Map Viewer website and that is not unique or part of the WAB application.
PRuss
okay, so even though "Edit this map" and "Create a map" are inside WAB they are technically not part of WAB ? please see attached sc.
Any idea where to find an answer to my original question about deleting custom images? I posted on AGOL forum and got no replies.
You can always contact esri tech support.
