"TypeError: g(...) is undefined" Using Analysis Widget
5620
07-27-2015 01:54 PM
MaryEllen_Perko
Hi.  I'm trying to add the analysis widget to a WAB app and am getting the following error when I click on any of the tools.  What am I missing?
If it matters, I've tried using the Foldable Theme, Jewelry Box Theme, and Tab Theme.  And I think i have the correct privileges.
Mary Ellen
Tags (3)
RobertScheitlin__GISP
Mary,
   I have not had any issue using the analysis widget. What is your permission level in your AGOL account? The analysis widget does consume credits for most operations.
MaryEllen_Perko
Thanks for the followup.  My privileges include spatial analysis and elevation analysis.  I thought those were the privileges needed to execute the tools in the map viewer.  In fact, I have no problem using the tools in the map viewer.
Also, I found that Chrome and IE10 provide a little more information:  TypeError: Unable to get property 'toString' undefined or null reference
Thanks again. It helps to know that it does work.
zhongrenGu
Mary,
     According to my experience, i think you give a wrong domain of a obj  maybe, you can reference
API Documentation - The Dojo Toolkit Version 1.10   dojo/_base/lang
MaryEllen_Perko
Thank you.  But for clarity, I am not doing any coding.  I am using the analysis widget through the web app builder hosted through AGOL.  Thanks.
SrinivasaKandula2
I am having same issue using Analysis widget through the Web app builder 2.0.
When I run widget for the first time it works. But when I tried to use second it throw "Unable to get property 'toString' of undefined or null reference.
Note: If you refresh the webpage it works again and the story continues.
I am not using any coding I am just using the widget which I build using Web app builder 2.0.
