Question about Web AppBuilder for ArcGIS
2388
08-28-2014 09:20 PM
DHEERABHATLEELAWUTTICHOKE
Question about Web AppBuilder for ArcGIS:
1. The final version of Web AppBuilder for ArcGIS will be included in Portal for ArcGIS 10.3 and ArcGIS 3.5, is it correct? If Install only AGS 10.3, can I able to use WAB?
2. Can I download and install it standalone without Portal installation?
3. Functionality of WAB in AGOL and Portal is the same or not? Can I customize Widget and Theme in both AGOL and Portal?
RobertScheitlin__GISP
Dheerabhat,
  1. WAB will be built into ArcGIS Portal 10.3 and available as part of AGOL. There will also be a standalone Developer version that you can download and install on your own machine (just like the Beta developer version).
  2. Same as #1 answer
  3. I can not answer this with 100% confidence but I do not believe that they will be different. As far as I understand yes you will be able to use custom widgets and theme on AGOL and Portal. I am sure this will be covered in the documentation once the release is final.
Thank you very much for your useful info.
