Query Widget export CSV
2457
08-17-2020 09:35 AM
AaronNash__GISP
I noticed when you add query results to the attribute table it will not allow you to export to CSV. The export button is available, when pressed nothing happens. I am on 10.7.1 enterprise. Has anyone experienced the same issue or aware of a workaround?
thanks in advance
KaitlynStevens
Hi Aaron Nash, GISP
This behavior was actually logged as a software defect
  • BUG-000123249 - Exporting an attribute table to a CSV file from a query layer created via the Query widget in Web App Builder for ArcGIS fails, returning no error message.
I did test the same in ArcGIS Online and it looks like the issue does not occur there, if this workaround works for you.
Hope this helps,
Kaitlyn
KaitlynStevens
Hi Aaron Nash, GISP
Hope this helps,
Kaitlyn
AaronNash__GISP
thanks for the update, we will have to wait for a fix.
