Query widget error
5524
8
02-04-2015 02:21 AM
MattiaCugini
i have an issue when opening the WebAppBuilder (the cloud version) Query widget configuration. After clicking con the "pencil" button I receive this error:
This happens also when I create an empty query widget; it doesn't let me configurate the tool.
Anyone is experiencing the same problem?
Thank you
Mattia
RobertScheitlin__GISP
Mattia,
   When you say the cloud version are you talking about AGOL using your AGOL organizational account or are you talking about your own local ArcGIS Portal install?
MattiaCugini
Hi Robert,
I am talking about AGOL using my organizational account.
Regards
Mattia,
   What browser and browser version are you using? I just tested my AGOL Org account and the query widget settings popup came up fine for me in FireFox 35.01
MattiaCugini
Robert,
I am using the same FF browser version. The error shows up also using Chrome and IE (last versions).
Also tried with several different computers.
It seems that there something corrupt in the application; unfortunatly it took a very long work deploying it, so it is not easy for me to just create a new one and retry.
Thank you
Mattia,
   I would suggest contacting tech support and see if there is anything that they can do for you, but it is likely that they will advise you to begin again.
MattiaCugini
I will try. Thank you Robert.
MattiaCugini
Update.
I have tried to create a new application but I am still encountering the same error. It means that the "Query widget" error is, at least, connected to my AGOL Organizational account (maybe, with the storage area where ESRI saves data uploaded on my account).
Who I have to contact for having this solved? The regional (Italy) ESRI office?
Mattia,
   I am not sure how international support works.
