Pulling ObjectID into related tables
892
05-10-2024 06:37 AM
MikhaylaB
I have a service with four layers utilizing the same point fc with a different definition query on each. The feature class has a related table related by ObjectID. They are labeled Active, Closed, Pending, and On-Hold.
The Active layer is turned on by default in the web map, and it is automatically pulling in the ObjectID when adding a related table record via the Edit widget in webapp builder. The other layers are not populating that field.
Is there a setting that handles this behavior? I can't find how or why it works for one but not the other three.
