Problem when authenticating arcgis web appbuilder
2531
05-17-2021 12:39 AM
hamidmechouet
Hello, I am here today to ask for help, I have a problem when installing the arcgis web appbuilder for the first time, I cannot authenticate myself. I cannot access the web app builder as soon as I confirm the authentication, it returns to the main page ...
anyone have any ideas how to solve the problem ?.
Tags (1)
BrianWilson
It's a pain and won't work until you get the "Redirect URI" setting correct. In my notes I say "https://localhost:3344/" and at some point I added "you must use HTTPS not HTTP". I know you can put many entries in there, if one does not work keep adding more 🙂 For example if you are accessing it from a different machine (using your machines IP address of course) you could put 4 lines in like this just to be sure something works. Good luck, I struggled with connections too.
http://192.168.1.1:3344/
https://192.168.1.1:3344/
http://localhost:3344/
BrianWilson
